No I have not been subject to unspeakable exposures in public, I save that for private sessions, but I am going nuts with people flashing me at night because they think I have main beam on.
I have checked the bulbs are fitted OK and they are 55w which I believe is correct. I have noticed that the beam line appears quite high compared to other vehicles I drive. Is there a way to adjust the angle of the beams mechanically. 95 model.
Ta
Aaaarggh! The flashing is getting to me!
There is indeed crazy...I didn't do mine personally, the mot tester did mine, as i'd just had the bongo lowered,and the lights were set way too high...
There should be adjuster screws at the rear of the headlight housing, a screw for lateral adjustment, and one for up/down...
I've just been out to check but i can't see, (battery gone in light
) Ill have a look tomorrow if nobody else knows...
