heated rear window
John the sparky
heated rear window
Post by John the sparky » Sun Nov 11, 2007 11:52 pm
noticed today that the heated rear window doesn't work....
or at least the light on the heating control unit doesn't work....
I have done a search using heated and rear and window, and there are a few threads.... but no solutions....
basically,I'm being lazy, and wondered if anyone could give me a start, before I strip the dash or something rash like that! and then find out it's that connector that always fails......
Also.... is there a fact sheet on drop links, can't see it, but is it hidden (well from me) under another heading
thanks
dreamwarrioruk
Post by dreamwarrioruk » Mon Nov 12, 2007 12:19 am
hi john check a factsheet in the members area i did for the electrics.
most likely damaged cable through the grommet in the tailgate, thats if you havnt already checked the fuse.
also what info do you need about the drop links, easy to change.
