Fire extinguisher
granitetim
Fire extinguisher
Post by granitetim » Sun Nov 11, 2007 8:51 am
Just wondered where to site my new fire extinguisher any ideas ? or where is yours sited ?
trevd01
Post by trevd01 » Sun Nov 11, 2007 10:31 am
Ours has a full side conversion and the fire extinguisher bracket bolts neatly behind the drivers seat, using the holes where the fold out seat/footrest once was.
Post by haydn callow » Sun Nov 11, 2007 11:17 am
On the plastic seat base cover by the side door
AndAndDen
Post by AndAndDen » Sun Nov 11, 2007 11:22 am
We have a Full Side Conversion. This is where ours is.
http://i133.photobucket.com/albums/q59/ ... ext001.jpg
Get a Life ,Get a Bongo. !!!
mobilecat
Post by mobilecat » Sun Nov 11, 2007 12:08 pm
Call me a devils advocate if you like but can the fire extinguisher on the photo at the back of the full conversion be taken out quickly without opening the rear door. If it can't I strongly suggest you move it!
trevd01
Post by trevd01 » Sun Nov 11, 2007 12:19 pm
The position behind the driver's seat is ideal, because we always have the driver's seat folded forward when cooking (don't want to get cooking splashes on the Alcantara :wink: ). I reckon you are most likely to need it for a cooker incident - so ours is right next to our cooker, immediately at hand.
Also another point - on our Wellhouse conversion there is less than an inch clearance between the back of the wardrobe and the rear door - it is contoured to follow the line of the door.
When people tell you a 'side conversion is a side conversion' there are important differences.
(Andy the pic is great, but just a tad too large...) :shock:
AndAndDen
Post by AndAndDen » Sun Nov 11, 2007 12:25 pm
mobilecat wrote:Call me a devils advocate if you like but can the fire extinguisher on the photo at the back of the full conversion be taken out quickly without opening the rear door. If it can't I strongly suggest you move it!
Yes mobilecat the extnguisher can be taken out quickly ( we have tried it :wink: ).AND you can remove it quickly without having to open rear door.
mobilecat
Post by mobilecat » Sun Nov 11, 2007 12:26 pm
I am glad about that. It is difficult to tell from the photo and I know how tricky getting the door open can be in hurry - not something you want to be fiddling with in a fire :)
granitetim
Post by granitetim » Sun Nov 11, 2007 6:52 pm
Thanks for all your replies I think I will have a bash at Haydons idea as this seems the most logical on my Bongo..
vanvliet
Post by vanvliet » Sun Nov 11, 2007 8:03 pm
Extinguisher frame bolted to the floor behind the passenger 's seat using the two existing floor mounted nuts ( no footrests /flipseats fitted ) They also double up to mount two steel cargo tie - down loops.
Easily accessed for use inside or outside the van
