Glow Plug Dash Light
BonGoRANT
Post by BonGoRANT » Thu Nov 08, 2007 10:24 pm
My new to me Bongo would not fire up this morning
and I referred to the HAND BOOK.
There is no dash indicator light for glow plug function( should be near headlight mainbeam warning light). Does this mean the glowplugs are not working?
How long should I leave the ignition key in the ON position for before
turning to START in the hope that the glow plugs are operational and
only a behind dash light bulb is required.
I live in GLASGOW.
Which is the best Bongo garage in central Scotland to head for if the engine starts?
Post by francophile1947 » Thu Nov 08, 2007 10:31 pm
About 5 or 6 seconds should do it. Has the light ever worked?
Post by Bob » Thu Nov 08, 2007 11:32 pm
Hi, welcome aboard, can't answer the first question but garage wise you could try Crawfurd Car Centre, 4-9 Crawfurd St, Greenock, PA15 1YN, 01475 787 540.
good luck fixing her.
floydster
Re: Glow Plug Dash Light
Post by floydster » Thu Nov 08, 2007 11:38 pm
BonGoRANT wrote:How long should I leave the ignition key in the ON position for before
turning to START
Less than ten seconds on a cold morning like today.
BonGoRANT wrote:I live in GLASGOW.
I was out at Campers Scotland at the weekend and was impressed with what they're up to. There are a couple nearer Edinburgh I wouldn't go near though.
I take mine to Powdrake and can't tell you how good their service is. They're only about 30 minutes from you.
Floydster
BonGoRANT
Post by BonGoRANT » Fri Nov 09, 2007 4:27 am
There is another dash warning light which my Bongo does not have.
HOLD. On taking off the plastic tray between the front seats and round the automatic gear shift there are two wires one black and one blue which are not connected to anything. The unconnected ends are near a small light bulb which actually works.
Any idea what these are for?
Bongoplod
Post by Bongoplod » Fri Nov 09, 2007 4:32 am
The small white bulb may be the bulb that illuminates the small green
indicator light/window in the ashtray
Brian
dandywarhol
Post by dandywarhol » Fri Nov 09, 2007 12:47 pm
Did you buy this Bongo from a dealer RANT? seems to have a lot of problems, including the ones you PMed me about.
If it is dealer bought - I'd take it back and tell him to sort it or shove it!
BonGoRANT
Post by BonGoRANT » Fri Nov 09, 2007 11:10 pm
Not from a dealer but at BCA auction.
Clean and tidy
My new toy
