air con
cliffy the climber
air con
Post by cliffy the climber » Thu Nov 08, 2007 6:39 pm
does anybody know if kwik fit know about bongos...?
i phoned them and they said bring it in and they would have a look but he didnt sound very confident..just want to get it recharged....
and by the way where is the air con unit on a bongo..??
thanks cliff...
heatherpetch
Post by heatherpetch » Thu Nov 08, 2007 6:46 pm
my brother-inlaw got his done there but cant help with where it is.
waycar8
Post by waycar8 » Thu Nov 08, 2007 6:48 pm
yes they should be able to top it back up, the aircon is situated just behind the radiator.
Dabs
Post by Dabs » Thu Nov 08, 2007 6:49 pm
From what I can remember they get mixed views some like em some dont.
If in doubt consult an expert!!
Dabs
Post by missfixit70 » Thu Nov 08, 2007 7:02 pm
Go in with the relevant info re amounts of oil & coolant required in both systems if you have front & rear. It's been discussed on here before if you do a search, top up info should be on the members factsheets.
paul9
Post by paul9 » Thu Nov 08, 2007 9:47 pm
had mine done there,no problems,but had to take info on how much gas and oil they needed to put in,also show em were connectors are under air scoop,they may need to put it on compuer as a B200,so they can get the print off results :wink:
annsvan
kwikfit
Post by annsvan » Fri Nov 09, 2007 4:58 pm
Had mine done at the Leigh branch. The main problem was locating the second point, which is as has been said located behind the radiator - visible from the passenger side.
cheers
:lol:
