blown a fuse???
flippa
blown a fuse???
Post by flippa » Thu Nov 08, 2007 5:58 pm
help needed again :roll: my radio won't work mirrors and the ciggie lighter all packed up at the same time, have i blown a fuse ????if so will it be the small ones by the steering wheel .....when it happened i was trying out a ciggie lighter insert ...the 12 v was operating a coolbox before , and now along with the radio and mirrors are kapput any ideas???
MountainGoat
Post by MountainGoat » Thu Nov 08, 2007 6:19 pm
If you look at the fuse chart in the members section you will find that the cigar lighter/mirrors fuse is the top right hand fuse in the box to the right of the steering wheel. It is rated 15Amps.
Post by bigdaddycain » Thu Nov 08, 2007 6:21 pm
yep, it sounds like one of the small fuses on the right lower hand section of the dash flippa...
I think its a 15 amp, but i could be wrong.
You'll need the little yellow tool that is attached on the inside of the flap to extract the fuses for checking.... :wink:
MountainGoat
Post by MountainGoat » Thu Nov 08, 2007 6:30 pm
I have one of those little yellow tools that Halfruds and others sell for removing fuses but find them a bit useless. You need to sqeeze very hard and pull at the same time to remove the fuses, hopeless if the fuse has solified.
Much easier with the tiny pair of long nose pliers which I keep in my glove box.
Post by bigdaddycain » Thu Nov 08, 2007 7:07 pm
Oops, you beat me to the answer mountaingoat...
MountainGoat
Post by MountainGoat » Thu Nov 08, 2007 9:00 pm
\:D/ \:D/ \:D/ \:D/ \:D/ \:D/ \:D/ \:D/ \:D/ \:D/
Post by bigdaddycain » Thu Nov 08, 2007 9:06 pm
:lol: :lol: :lol:
flippa
Post by flippa » Fri Nov 09, 2007 3:40 pm
cheers guys =D> =D> =D> spot on info as usual the fuse had blown just had to swap it with another i think i have disarmed my lecky closing mechanism on the sliding door but i need me cd player and 12 v socket more
till i get some spares thanks again guys :wink:
Post by bigdaddycain » Sun Nov 11, 2007 2:24 am
Glad its sorted Flippa :wink: Those seats in your avatar look quite interesting..... i'm intrigued :-k
flippa
Post by flippa » Sun Nov 11, 2007 5:20 pm
lol big d :lol: just two cheap throws from a market stall they fit quite snug and a cheap alternative to recovering or new seats and a.k.a flippa...i thought i'd carry on the dolphin theme....and its a bit of fun :lol: :lol: :lol:
