radiator
heatherpetch
radiator
i have got the bonnet up at the moment having a clean and a check,the radiator knob that is screwed on to the platic tub that says engine coolant only appears to be pretty empty do i add just water please or something else.Thanks in advance
- westonwarrior
- haydn callow
- haydn callow
- dandywarhol
Surely if it's topped up to the FULL line when cold you aren't leaving enough room for expansion and it willcause the expansion tank to be too full/overflow.
Aren't you better to fill it to the lower mark when cold??
- haydn callow
Have always filled to the full line when cold. Never been a problem and I think that is what is intended.
We put the probe/sensor for the loss alarm about 1cm below the full line so at least 120 other bongos also fill to that line.
When hot the level goes up about 1 to 1.5cm so there is plenty of room for expansion.
Hope that explains.
Hope that explains.
