Rear Drop Links
Rear Drop Links
in the sticky
for the parts list you say that ford Galaxy and vauxhall vectra drop links will fit front and rear just to queery are these both for the front of the bongo if so which parts fit the rear of the bongo
Re: Rear Drop Links
vectra for the frontsearchers wrote:in the sticky
galaxy for the rear
make sure you change the galaxy rears in pairs as there is a slight difference in length
rob
Re: Rear Drop Links
Bought both they were just about the same lenth with what looks like track rod endsrob and karen wrote:vectra for the frontsearchers wrote:in the sticky
galaxy for the rear
rob
Rear ones are about 3 inches long with a rubber bush at each end
I went to a local motor factors for Galaxy rear drop links, and quoted the part numbers I found in the search section of this site. When the factor came out with them, they looked nothing like the Bongo ones. I went home and found another part number from another search, but when I quoted this one to the motor factors they said that they didn't stock them, but could get them for me. The price however was quite a bit more than getting the genuine article from Ian! No prizes for guessing where I got mine.
Rear droplinks
http://cgi.ebay.co.uk/Mazda-Bongo-rear- ... dZViewItem
Front droplinks
http://cgi.ebay.co.uk/VAUXHALL-VECTRA-9 ... dZViewItem
Front droplinks
Drop links
I spotted this site, could be worth a look. Let me know if its of any use.
Trhttp://www.southwalesprops.co.uk/propshaft/veh ... bongo.htmy
Re: Drop links
Link doesn't work - I think you need to remove the Tr from the beginning.johnny7 wrote:I spotted this site, could be worth a look. Let me know if its of any use.
Drop links
Ok, maybe just try; http://www.southwalesprops.co.uk
look under; vehicles then Mazda then Bongo.
Hope it works this time, there only £15.00.
Drop links
I sent them an email, reply below;
Hi John, SWP2090 = £14.95 & SWP2326 = £12.95 + VAT
AMTRAK carrier = £7.50 up to 20kg
Thanks & regards,
Mike Henderson
Maybe he can do a club discount?
Thanks & regards,
Mike Henderson
Fitted mine the other day. Quite a straight forward job except for getting the wheels off, which makes it easier to get a socket on the bolts! The wheels seemed to be stuck hard onto the centre boss of the hub. Had to resort to placing the jack between the bottom of the rear suspension and the wheel rim and then opening it up. Rear axle was of course supported on axle stands.
Great to have done it as there is now no more knocking when going over bumps.
- dandywarhol
Slightly off thread here but I fitted a front set to mine at the weekend - what a difference to the general "feel" to the van - no clonks but also it's tightened up the steering and given it more feel, also the slight "tremor" at 65 was creping back in again, now gone!
I suppose thats down to the top link swivel moving along with the strut from lock to lock - kinda acting as a friction damper..........
