Post
by John the sparky » Sat Oct 20, 2007 4:24 pm
it is fairly easy, but a bit of a pain.....
disconnect the battery and leave for 10 mins to half an hour, for everything related to the airbag controller to discharge,
then disconnect the airbag, which is normally a couple or three screws behind the steering wheel, then remove the wheel (by undoing the big nut!)
remove the wheel and compare the airbag connections (don't know on the bongo/freda but on seat's and vag cars there is a yellow connector) and also the lead that is wound up for the connections, (the bit that stops the cables breaking when you turn the wheel, probably a flexible circuit board type thing)
if the connectors are the same, bingo, rebuild then reconnect battery.
if not replace with the old wheel..... grrrr
on vag cars the connectors seem to change every couple of years, and if you haven't already got the wheel it will be an expensive way to find out... probably better to take yours off and find out the connections first and then wander round a scrappys!
so the short answer is probably NO, swap with type for type!
