Wi11iBongo
Post
by Wi11iBongo » Tue Oct 16, 2007 9:03 pm
Hi All, As topic says im a proud new bongo owner
I've just imported a 2L petrol yr2000 tintop model. Has anyone had experience with this model?
Finding info very thin on the ground for it!!! Basically I'm trying to get some knowledge of whats needed for the SVA test, I know it needs a fog lamp and the speedo needs to be sorted (seen kmph>mph converters on ebay dont know how god they are though!!)
Any Info greatly appreciated
brorabongo
Post
by brorabongo » Tue Oct 16, 2007 9:10 pm
Wi11iBongo wrote:Hi All, As topic says im a proud new bongo owner
Hi Wi11iBongo and congratulations on your purchase
I don't know much about SVA etc, but as for the speedo why not get a new dial/clock from a scrappy, plenty posts on here about suitable dials. Converters I hear can cause problems?.
As far as I know, it does not matter about the mileage being in km's (mine still is)
ボンゴの激怒 pictures
Run your fingers over my Bongo, and I'll run my Bongo over your fingers!!
brorabongo
Post
by brorabongo » Tue Oct 16, 2007 9:17 pm
ボンゴの激怒 pictures
madmile
Post
by madmile » Tue Oct 16, 2007 9:19 pm
I dont know if the 2lt petrol is the same speedo face as the diesel, but if it is then Bongo bits have got the new shape speedo faces in - why bother with a replacement speedo when a £10 face is all thats required?
I am not an expert on SVA, but I wasn't aware that a model report was available for a 2.0lt petrol?
Wi11iBongo
Post
by Wi11iBongo » Tue Oct 16, 2007 9:23 pm
Thanks for the welcome and the swift replies!!
Is it a big job to replace the speedo face, do I need to remove the dash board etc.? did have a browse through the topics but couldnt find anything on it. As regards SVA test I keep comming across statements about model reports and other stuff I'm not sure about Will read the pda doc, thanks again!
Wi11iBongo
Post
by Wi11iBongo » Tue Oct 16, 2007 9:31 pm
madmile wrote:I am not an expert on SVA, but I wasn't aware that a model report was available for a 2.0lt petrol?
What does that mean to me in real terms? I'm still not 100% clear on the model report stuff.
brorabongo
Post
by brorabongo » Tue Oct 16, 2007 9:41 pm
Wi11iBongo wrote: Is it a big job to replace the speedo face, do I need to remove the dash board etc.?
Not a big job, If I remember right, just needed a screwdriver and the disconnection of switches (fog light etc)
This might give you an idea
( first picture on third page)
Click here
ボンゴの激怒 pictures
Post
by mikeonb4c » Tue Oct 16, 2007 10:00 pm
Welcome Wi11iBongo - cant help on the SVA business I'm afraid. I've a vague feeling there is a factsheet in the Members Area - have you tried there?
madmile
Post
by madmile » Tue Oct 16, 2007 10:00 pm
The SVA test in addition to a few simple jobs(on a Bongo) requires the use of a model report to compare it with certain information prepared on a certain type of Bongo. If there is not a model report available for your particular model then putting it simply you cannot pass an SVA test.
The reason I dont think there is one for a 2lt petrol is that one of my trade customers has a 2lt that he has asked me to convert to a camper for him, and normally he sells them unconverted.
The speedo face swap is a 20 minute job. The most difficult part is prising off the needle with the use of a teaspoon!
Wi11iBongo
Post
by Wi11iBongo » Tue Oct 16, 2007 10:23 pm
thanks for the replies. It's looking grim then
Can anyone confirm madmile's post? Also I take it from the reply that If it's converted to a camper then the SVA test is not required?
Post
by francophile1947 » Tue Oct 16, 2007 10:26 pm
Wi11iBongo wrote:thanks for the replies. It's looking grim then
Correct - no SVA if converted. The trouble is that 2.0 litre vans are rarer than hen's teeth, so not much to go on for a model report.
Wi11iBongo
Post
by Wi11iBongo » Tue Oct 16, 2007 11:03 pm
Thanks for the reply Trevor, I did read that earlier but as I say, didn't have much idea what a model report was etc. also topic was regarding a freetop but I guess it applies to tintops too.
trevd01
Post
by trevd01 » Tue Oct 16, 2007 11:05 pm
