tappet clearance settings
lee13
Post by lee13 » Fri Oct 12, 2007 11:43 pm
hello all last saturday when heading from home to auckland international airport i managed to get about three miles down the road heard a strange noise looked at the guages to find it on hot
i am now fitting the new cylender head and need to know do you set valve clearance at the valve or at th cam my reason for this question is you would need some very thin feeler guages to do at the valve end so i thnk set them at cam but......
thanks lee
Harry
Post by Harry » Fri Oct 12, 2007 11:54 pm
Hi Lee
We need to kno2w which engine you've got.
The vast majority of UK bongos have 2.5 turbo diesels.
There are a few petrol jobbies. either 2.5 or 2.0 litre
http://watcherswildlife.co.uk
lee13
Post by lee13 » Sat Oct 13, 2007 2:39 am
oh sorry 2.5 diesel turbo wl-t
they ar known to stuff there heads with a bit of a cook up
MountainGoat
Post by MountainGoat » Sat Oct 13, 2007 11:17 am
My Manual says:
No.4 is set at TDC
Standard Value
IN: 0.1 ± 0.05mm (Cold)
OUT 0.2 ± 0.05mm (Cold)
Only one set of values given so must be the same for both types of Bongos.
trevd01
Post by trevd01 » Sun Oct 14, 2007 2:05 pm
Lee13
If you are in NZ, please put your location in you profile.
Could save a lot of confusion/frustration.
(unless you happen to live at Auckland, Chester Le Street, Durham DH2, UK, which I dont believe has an International Airport) :D
Peg leg Pete
Post by Peg leg Pete » Sun Oct 14, 2007 7:45 pm
:shock: :shock: :shock: :shock: :shock: :shock: :shock:
Image Pete
