Rear interior light staying on
Posted: Tue Oct 09, 2007 6:53 pm
by bongolow
Would I be correct in assuming the rear interior light switch on the tailgate is just a simple 'connect-down-to-chassis' job? It doesn't operate a relay does it?
My light is staying on when I shut the tailgate but it's not the switch - it stays on even if I disconnect it inside the rear panel. If it's not operating a relay then I must have a short circuit down to chassis somewhere. I wouldn't bother if it was just the light but the alarm thinks the door is open.
This just happened today after I fitted the Mason alarm but I can't believe there's anything behind the dash I could have pulled off that would cause this.
Posted: Tue Oct 09, 2007 11:43 pm
by dandywarhol
I think the switch is connected to the tailgate opening switch bongolow
Posted: Tue Oct 09, 2007 11:47 pm
by bongolow
Yes, I found the switch and it's working OK but the light is staying on even when it's disconnected. I just wanted to check that it didn't do anything devious like operate a relay or summat. I'll investigate further tomorrow.
Cheers....
Posted: Wed Oct 10, 2007 11:29 am
by bongolow
OK it's sorted. To cut a long story short - the burglar alarm fitters had connected a wire from the back of the interior light and joined it to a wire under the dash. The fitter had soldered the wires together and wound insulation tape over it but had left a tiny bit of bare wire at the end. This was touching the metal strut next to the fuse box.
I'm wondering if this has been the cause of another problem I've had for a while - the alarm has been going off on it's own very occasionally.
Posted: Wed Oct 10, 2007 12:50 pm
bongolow wrote:OK it's sorted. To cut a long story short - the burglar alarm fitters had connected a wire from the back of the interior light and joined it to a wire under the dash. The fitter had soldered the wires together and wound insulation tape over it but had left a tiny bit of bare wire at the end. This was touching the metal strut next to the fuse box.
I hope the burglar alarm fitters are making suitable recompense Vince :roll:
Posted: Wed Oct 10, 2007 4:05 pm
by bongolow
Ha! Fat chance.... :D :D
