coolant alarm kit.Help needed please
AndAndDen
Post by AndAndDen » Sun Sep 16, 2007 5:45 pm
Please help as i'me only a novice trying to find my way, Got the coolant alarm kit, In the contents you have a short earth probe wire 2 x ring terminals (purple) one end to the header tank but where does the other end go to :? , Also you have the twin wire red/black, black wire from module to where?maybe header tank? :? Thanks Andy
Get a Life ,Get a Bongo. !!!
Post by haydn callow » Sun Sep 16, 2007 7:57 pm
I think the instructions cover this. However. The short wire with 2x ring terminals goes from the bottom probe to the battery earth terminal. The red wire from the modual unit goes to the 12 volt switched supply at the back of your fuse box and the red/black wire goes to a earth. Please phone me if you have any more problems
Haydn 01458 270230
Post by haydn callow » Sun Sep 16, 2007 8:02 pm
The long wire with the ring at one end and bullet connector at other goes from the top probe to the female bullet which is attached to the module.
