Front diff
gtmpaul
Front diff
Post by gtmpaul » Mon Sep 10, 2007 10:10 pm
Hi all,
I want to check the oil level in the front diff, we have an SGL5,
I'v gone through the check sheets on lubricants etc, I can find the oil type but only how to check the rear diff.
anyone know.
Paul
Post by francophile1947 » Mon Sep 10, 2007 10:16 pm
No - but I'll be interested to see the responses myself. I suppose I ought to check it sometime :lol: :lol:
Ralph
Post by Ralph » Tue Sep 11, 2007 11:31 am
Look under the Bongo from the drivers side through the
gap between the front wheel and wheel arch you can see
the front diff, you will see 2 large bolts/plugs about 19/20 mm
the bottom one is the drain the one on the nose of the diff
casting NR were the prop shaft joins is the level/filler undo
it if oil comes out all is well if not add oil till it does.
don't touch the bottom one unless you intend changing
the oil the bottom one as a magnet fitted so you can get
a idea if all's well.
Post by haydn callow » Tue Sep 11, 2007 1:24 pm
Next Qiestion.
What type of oil please.??
Post by bigdaddycain » Tue Sep 11, 2007 1:59 pm
If your bongo has a limited slip differential paul, you will need to use a (SAE90) GL-6 gear oil.
Or an (SAE90) GL-5 oil for 4x4's with no L.S.D.
Ralph
Post by Ralph » Tue Sep 11, 2007 2:57 pm
EP 90 Hypoid gear oil, GL-5
same for front/rear diffs and transfer box
you need about 6 liters to change all three
something like 1.85 litres in each.
