roof
				heatherpetch
roof
please can anyone tell me when the roof rises should it stop bleeping when it gets to the top,ours carries on
						- haydn callow
				jimsmimm
- haydn callow
- maxheadroom
				Veg_Ian
That's an interesting observation Max. Yesterday I raised the roof to fit yet another patch to the netting and decided to try it without the engine running (first time I've done this) and sure enough the bleeping continued until I switched the ignition off. It appeared to have opened fully but maybe it needs the engine running to get it fully extended.
						If Your engine is running it just means there is less stress on the electrical draw from the battery as it is driven from the vehicle battery.I think I am right in saying its quite a big event in battery terms so its always best to have the engine running.
It is also important to ensure that the mechanism is well lubricated too which does reduce any drag and friction when its being lifted thus making it easier on the motors and batteries when operated.
Dabs
Dabs
				Simple Simon
 - Bongonaut
				Veg_Ian
It's recommended to use white lithium grease as it applies as a thin film of oil. Anything else and it gets everywhere (I found out the hard way and have spent ages cleaning grease off everything). Apply to the runners and rollers. Having said that it still creaks and groans for the final part of the lift.
						- maxheadroom
