Turbo gauge
Ozric
Turbo gauge
Post by Ozric » Thu Aug 30, 2007 4:43 pm
Has anyone fitted a Turbo Gauge to their belovered or their bongo?
If 'Yees' is it easy to do?
trevd01
Post by trevd01 » Thu Aug 30, 2007 7:29 pm
...err Ozric,
why would you want to do this?
I am only asking because I cannot imagine what benefit it would provide?
But I'm sure you have a reason...
Post by bigdaddycain » Fri Aug 31, 2007 12:54 am
To see if the turbo is holding boost? :wink:
That way you can hold her at maximum boost on a long uphill drag,saves having to "hold" the auto... :wink:
Post by Ian » Fri Aug 31, 2007 9:00 am
That would make sense. I know Ozric is thinking about towing a caravan.
Ozric
Post by Ozric » Fri Aug 31, 2007 10:52 am
The idea is so I can see when I'm using the turbo (fuel) really just out of interest of what the turbos doing. And I like little gauges :D
Post by bigdaddycain » Fri Aug 31, 2007 2:16 pm
Nowt up with that...The more info you have at hand the better! (especially whilst towing) I reckon you'd have a visual indication of the optimum torque characteristic of the bongo engine, instead of just "feeling" for the tip of the torque curve.
Economy may improve too,as you'd be able to adjust the throttle position to take full advantage of the torque...Using the torque of the engine is always a better bet than revving the knackers off it :shock:
Yes, the extra gauges are nice too :wink:
pippin
Post by pippin » Fri Aug 31, 2007 2:46 pm
bigdaddycain, not a good expression to use in front of me at the moment!
Peg leg Pete
Post by Peg leg Pete » Fri Aug 31, 2007 9:54 pm
Poor Pippin :oops: :oops: :oops: :oops:
Image Pete
Post by bigdaddycain » Sat Sep 01, 2007 12:30 am
Oops! sorry pippin :oops: :oops: :oops:
I meant to put "knickers"...honest! :wink:
harpo42
Post by harpo42 » Sat Sep 01, 2007 2:55 pm
I have fitted a turbo boost gauge. Very easy to fit. If you look at the turbo there are a couple of small rubber hoses (approx 6mm) which come from the pressured side of the turbo. (wifes out in the bongo at present will try to take some picture later). Simply tee into these and run to the gauge. No problem. :D
I fttted the gauge as I like to mointor. i figure that if you know what something (water temp. oil pressure, voltage etc) does normally, you can spot very early when it starts to do something that it shouldnt.
Just my opinion. :shock:
harpo42
Post by harpo42 » Sat Sep 01, 2007 2:56 pm
Oh and whats wrong with pippin? or shouldnt i ask?
pippin
Post by pippin » Sat Sep 01, 2007 3:08 pm
See "minor surgery" on Off Message section!
Ozric
Post by Ozric » Sun Sep 02, 2007 4:02 pm
Cheers Harpo and Cain just what I wanted to hear. There's another job to add to my list :?
