Problems Starting
Stu-B
Problems Starting
Anyone help the problem I have which has been getting worse, when I try to start my Bongo there is just a click probably relays, then I have to put it into N then P and more the key in the ignition. Any suggestions?
Veg_Ian
shakey
Stu-b, if it is your starter contacts, give Auto Electrical Supplies (Southampton) Ltd a ring on 023 80 211988 ask for Paul. Part no. *230221/13256 plunger and contacts, £16.45 inc. vat and postage (or it was in June when I did mine). There is a tutorial somewhere on the the site, but it's only a 20min job
. Shakey.
- haydn callow
shakey
Haydn, you got me there feller, I haven't a clue, mine is a softy, warm climate 2wd
, sorry. Those parts are both the same size, whereas my Bongo originally had one contact a slightly different length on its circumference, but they fitted the starter fine and I've had no problems since. I suggest try to find a manufacturers part no. on the starter and give them a ring, very helpful guys, they stated they didn't do mail order 'till I said it was a long way to collect from Lancashire, so they posted them.
Shakey.
- haydn callow
