Equipment for lifting a Bongo?
I'd like to lift my van up by 800mm on my drive way, after dropping my engine, so I can roll it out.
Can anyone suggest a safe way of doing this, or know of a hire company who can provide equipment to do this?
Rob
Rob
800mm is 80 cm so 31.496063 inchesDavid Edwards wrote:Firstly how much is 800mm in real measurements
- helen&tony
lifting Bongo
Hello Rob’n’Kathryn
See if a small local recovery firm with a spectacle lift truck would spare 5 mins.
to raise your van while you pile a few railway sleepers under it. There’s often a small independent who may oblige.
Hi Helen & Tony......thanks for the idea.......that's well worth a thought.
Actually, I wouldn't need to do the sleepers bit.....I only need the vehicle raised long enough for me to roll out the old engine and roll in the new.....30 mins max. All other work can be done at a 'normal' raised height on axle stands. I'm not sure if a spectacle lift would leave the side clear to roll the engine in or out though......to be truthful I haven't a clue what a spectacle lift is at all!
Rob
Rob
- boyfrombrasil
Thanks Kirsty, yea I know exactly what you mean....the recovery co. which came out when I achieved Bongo engine armegeddon were going to use one of those until I told them the error of their ways.
I'll have a chat with an RAC mate who will know if it'll lift the front high enough to achieve the required height at the back.
Cheers....Rob
Cheers....Rob
- Pete & Sue
- Tribal Elder
- boyfrombrasil
Hi robnKathryn, dunno if this will work... Approach your local garage,and see how much they will charge you for hiring a four poster ramp for a sunday? (if they close sunday,it'll be worth their while)
Measure the width of the bongo's engine width at its extremities,then measure the gap between the rails of the ramp that the wheels sit on.
If the gap is wide enough for the engine to clear the gap,you could undo the engine mounts and ancilleries,(after placing a trolley jack below the engine)raise the jack(s) to take the weight of the enginethen very slowly,and very gently,raise the bongo up,taking care to steady the engine on the jack(s) axle stands or whatever.
When the bongo has been sufficiently raised,wheel out the jacks with engine on top
Finish off by Popping a sheep in the empty engine bay to ward off any scallies.
Vanlift
I would imagine that if the engine is duff then getting it to a local garage will be quite difficult. You will also have to transport your new engine there as well if you are replacing the old one but if you are removing your old engine to work on it then you will have to arrange transport home for the van and engine - and by the way, when you come to refit the engine you will have to also arrange transport back to your local garage. I don't think this is on, do you?
What you need is a method of raising the whole vehicle 30 inches in situ - not an easy operation to carry out safely at home. If you do not feel entirely confident you have the necessary tools and experience to do this then leave it to the pros.
