coolant type?
aid175
coolant type?
Post by aid175 » Mon Aug 06, 2007 5:22 pm
can someone tell me if there is a special type of coolant required for the bongos please.thank you.
Peg leg Pete
Post by Peg leg Pete » Mon Aug 06, 2007 7:09 pm
I used coolant from local unipart depot, forget the brand name, as long as it is suitable for alloy engine :wink:
Image Pete
aid175
Post by aid175 » Mon Aug 06, 2007 7:10 pm
cheers pete.
smartmonkey
Post by smartmonkey » Tue Aug 07, 2007 11:09 am
You can use whatever coolant you like as long as you match what is in or replace the whole lot. Check you get good quality and it has the corrosion inhibitors for aluminium engines (hard to get stuff that doesn't now).
