As it was mentioned on here I took instructions and thanks to Somersetrebel and Misfixit I set about replacing it
Broken aerial
Removed and aboout to saw off stub at mount
Once cut I drilled out the middle to correct size for brass screw
Then a thread was tapped
once the thread was done Its put together(shows tap and die set and differentsize brass bits
Finaly fit back to bongo with the new bearing I perchased
all works and should now not break so easy and more than a third cheaper than a mazda origonal
