Key in ignition beep
dp bradford
Post by dp bradford » Sun Jul 29, 2007 11:41 am
Now I know this has been done before, and I've searched for the answer to this but I've not found it... So, here goes:
I've just disconnected the white connector under the steering column shroud to stop the key in ignition beep. Great 8) no more beeping simply because the key's in - BUT now the reversing beeper only works if the lights are on :?
Is there a way to stop JUST the key in ignition beep????
If it's complicated, I'll probably just live with it as it is :roll:
Dave
daveblueozzie
Post by daveblueozzie » Sun Jul 29, 2007 4:32 pm
if you have the beeper under the side panel near the steering wheel connecting to the blue beeper box then just cut the white wire.thats what i did no beep with ingnition or doors everything else works ok.
Lost without my Bongo.
dp bradford
Post by dp bradford » Sun Jul 29, 2007 5:53 pm
Thanks. I'll give it a go when my new supply of tuits arrives.
Cheers 8)
daveblueozzie
Post by daveblueozzie » Sun Jul 29, 2007 7:36 pm
ok i give up whats a tuit ? :?
