bee sting antena
Posted: Fri Jul 27, 2007 4:53 pm
by westonwarrior
Any one fixed one of these instead of the original bongo aerial?
how did you do it as I have broken 2 aerials now and want something different.
any ideas pics would be very much appreciated
Posted: Fri Jul 27, 2007 5:41 pm
by maxheadroom
I have only ever fitted one to my VW Golf, no probs really. Only thing is having the courage to drill a hole in your roof. Just put some masking tape down to stop the drill bit slipping. Don’t forget measure twice, cut once.
Would a bee sting or shark fin (BMW) fit onto the rear spoiler, without fouling the roof when the door is opened?
Good luck and pics please if you go ahead.
Posted: Fri Jul 27, 2007 6:17 pm
by westonwarrior
Im sure some one has one in their existing mount how ever I was toying with mounting 2 at the rear of the roof for bling
Posted: Fri Jul 27, 2007 6:30 pm
by Colin Lambert
Could you not just screw the bee sting into the broken stub of the original aerial?
Franco, these are bee stings.
Posted: Sat Jul 28, 2007 8:44 am
by somersetrebel
Yes, i've fitted one of these all you need to do is as follows
1- Remove the original aerial ( be careful not to lose the ball bearing)
2- Cut off aerial thats left flush with the the mount
3- Get an electric drill and drill out the remaining part of the areial from
the mount
4- Screw in the brass double ended screw that should come with the bee sting
5-Put the mount now fitted with it's brass screw back onto your Bongo (carefull once more not lose the ball bearing)
6-Now screw your new bee sting onto the brass screw now remounted on the Bongo
7 - Now turn on your radio enjoy the cyrstal clear sound and look at your s**t hot aerial, smug knowing you saved a fortune not buying a Mazda original
Hope this helps and sorry i can't show you any pictures at the moment only my cameras broke at the mo.
Posted: Sat Jul 28, 2007 8:58 am
by westonwarrior
Thankyou most kindly
I drove through street yesterday evening, we went on a cruise
