Mysterious rattle from footwell/under engine area
caznsue
Post by caznsue » Thu Jul 26, 2007 8:50 am
any more suggestions....... have got a rattle which sounds like its coming from the passenger foot well. only does it when stationary...
worse with the air con on and even nosier when in reverse and stationary...
can not hear it at all whilst driving along,
engineer thought the gear box bush/mount, but no thats not it,
he took a look again yesterday and a plastic shield on the bottom underneath was loose, so tightened that and not that either.....
any other suggestions,
he also checked the engine mounts.....no not that.....
exhaust.........no
running out of ideas now............
sounds tinny and like a floor board rattling...........
daveblueozzie
Post by daveblueozzie » Thu Jul 26, 2007 9:44 am
andandden had a rattle it turned out to be a pipe touching metal cover over engine, tied it down and no more rattle so look for any loose pipes ,easy fix for them hope it is for you.
Lost without my Bongo.
caznsue
im stuck
Post by caznsue » Thu Jul 26, 2007 9:49 am
thanks for that, will get him to take a look for that,
keep em coming,,,,,,,,,,,,,,
Post by Ian » Thu Jul 26, 2007 10:11 am
Are all 3 clips on the central cowling secure?
Post by haydn callow » Thu Jul 26, 2007 10:30 am
power steering pump??. Does the noise get less when you turn the steering wheel a bit ??
caznsue
stuck
Post by caznsue » Thu Jul 26, 2007 11:39 am
thanks for those, it does not do it at all when being driven, its something that vibrates very loudly.....when i am stationary and it rattles if i give it a little more revs it goes............ will get the central cowling checked
thanks all
xx
mick
Post by mick » Thu Jul 26, 2007 11:44 am
It wouldn't be something as simple as the toolkit rattling in the footwell side pocket would it :?
Post by haydn callow » Thu Jul 26, 2007 11:46 am
Power steering pump!!!
caznsue
stuck
Post by caznsue » Thu Jul 26, 2007 11:51 am
thats a good one...........ummmmm, i wonder, it is that sort of a noise.....every time my engineer turns up it does not do it,,, he thinks ive lost the plot, especially when i rang him from my mobile this morning at 8 o clock and played him live rattle music!!! he he.....there can you hear it.......he said take the bloody thing out of reverse to shut that dam beep up and i might be able to......chuckle chuckle.........
it sounds like a metal cake tin full of cake bouncing around under the foot well........
aint it hard to describe a noise......
RobnKathryn
Post by RobnKathryn » Thu Jul 26, 2007 11:57 am
Just another possibility...........under the central cowling the throttle cable is secured to the front of the cam cover, with a metal bracket and nut/bolt....if the nut and bolt loosen and fall off which is not uncommon, then the bracket will vibrate against the cam cover or some other metal component. This sounds unlikely as you say the noise is nearside...but it can easily be checked by lifting the drivers seat and following the thick black throttle cable until you find the bracket..just make sure it is tightly secured.
Anyway I would lift both drivers and passengers seats then run the engine at tickover and at revs up to about 2500 rpm to see if you can get a better idea of the source of the noise.
Rob
Post by haydn callow » Thu Jul 26, 2007 11:58 am
does the noise lessen when you move the steering wheel???
caznsue
stuck
Post by caznsue » Thu Jul 26, 2007 12:01 pm
oh its good here aint it.........will give the steering wheel a turn later....what does that mean then if the rattle stops whilst im stationary and turning the wheel........
my engineer is going to love me, i keep printing off your answers....he he....got to keep the old chap earning his money.....bless him,
Vanmanerik
Rattle
Post by Vanmanerik » Thu Jul 26, 2007 12:15 pm
Have you looked in your glove box to see if there is any loose change etc. in it rattling around? :roll:
If not then park on level ground, engine off, handbrake on, wheels chocked and have a good look underneath and shake everything that looks as if it may vibrate when the engine is running.
Best of luck.
Post by haydn callow » Thu Jul 26, 2007 12:17 pm
Is this a new noise ???
If it lessens when you move the steering wheel it will be the power steering pump. Most Bongos do it to some extent. Depends how bad it is. Mine is quite noisy and so are most I have listened to.
If thats what it is I wouldn't worry to much.
Check the fluid level!!
dreamwarrioruk
Post by dreamwarrioruk » Thu Jul 26, 2007 8:39 pm
someone once said to me you get a rattle under the passenger side below the glovebox when the fan blower is out of balance, having heard it its not something that mine has but its like a fan rubbing against something.
again might be something to check.
