Sediment Warning Light?
Posted: Sat Jul 14, 2007 9:28 pm
by BettyBongo
Hello there. The "Sediment" warning light has recently appeared on my dash board. Any ideas what this means and how to rectify it? My handbook is next to useless. Have recently used some Biodiesel......could this be the cause?
Posted: Sat Jul 14, 2007 9:35 pm
by Peg leg Pete
Sediment
Posted: Sun Jul 15, 2007 12:30 am
by Vanmanerik
If you have recently started using Bio-Diesel it can have the effect of scouring your tank and fuel pipes and the sediment will be in ther bottom of your fuel filter, hence the Sediment light is on.
If the filter requires changing then follow the link above, if it has been changed recently then just carefully unscrew the plastic 'tap' on the base of the filter and the sediment and any water will drain out, when clean diesel is running out then tighten the'tap' up again.
Hope this helps.
Thank you very useful
Posted: Sun Jul 15, 2007 9:42 am
by BettyBongo
I'm new to Bongo's. It's fab to be able to pick the brains of more experienced folk
