waxoil & spare wheel
Posted: Mon Jul 09, 2007 12:17 pm
by missfixit70
Ok, yet another waxoil question, after crawling underneath fitting my towbar, I have come to the conclusion that I can do this myself :? but what about the area under the spare wheel, is it better to use a galvanising spray or solid setting underseal?
Other than diff, gearbox & brakes, anything else to avoid with the gunge?
any dismantling necessary, when fitting the towbar I did the area above the exhast back box that seemed a likely looking litle rust trap & liberally covered all the fresh holes & areas between towbar & bongo ( thanks to the guys that recommended towbar wiring through bumper & up into lights, dead easy :D (ish)).
Posted: Mon Jul 09, 2007 8:20 pm
by shakey
Hi Kirsty, if you use soft waxoyl type above the spare wheel, wrap the spare in plastic before replacing, then, if you need to change a wheel, you won't be covered in black sticky underseal that will get transfered to the tyre. Also carry latex gloves with the tools. :wink: Shakey
an easy alternative
Posted: Wed Jul 11, 2007 5:39 pm
by johnzbenson
You could get a 400 ml tin of galvanising spray paint from Screwfix for
£2.87 or therabouts http://www.screwfix.com/search.do;jsess ... t&x=11&y=6#
Posted: Thu Jul 12, 2007 2:52 am
by bigdaddycain
You could try the same thing as i have done miss fixit,get all the waxoiling done, including above the spare, then pop the wheel straight back up,and hope and prey you never have a puncture! [-o< [-o< [-o<
I,m more bothered about it splatting up the side of me bongo when up to speed than getting myself dirty! ah sure do lurvv mah bongo! :lol:
