blower not working
stefanovic
blower not working
Post by stefanovic » Sun Jul 01, 2007 1:18 pm
My fans not working at all. Could it be a fuse or something more serious?
Colin Lambert
Post by Colin Lambert » Sun Jul 01, 2007 1:24 pm
Check the drain hole in the gutter below the centre of the windscreen (open Bonnet) if it is blocked then the likelyhood is that the heater motor is f****d (that's FINISHED!!) by ingress of H2O.
Remove the trunking to the motor air intake and WITH IGNITION OFF!! stick you hand up the hole and try to turn the vanes. If they won't dudge you are in the doo-doo!.
Check the fuse first!! Fuse box display annotating which one does wot in the memnbers area!
Good luck!
Vanmanerik
Fan
Post by Vanmanerik » Sun Jul 01, 2007 3:04 pm
Go here http://www.igmaynard.co.uk/bongo/forum/ ... sc&start=0 its a load of woffal for the first 6 or 7 posts then it gets interesting.
The fan resistors are under the bonnet just behind the heater motor housing, lift the flap up, remove wires, undo two screrws and lift the unit out. The rest is in the link above.
Hope this helps.
