Post
by sandstone » Sat Jun 30, 2007 1:20 pm
I have waxoyled other vehicles and had my bongo waxoyled by a body shop.
When I have applied it myself it has taken some time to harden, and it could be smeared off with a finger for a few days.
For the bongo the body shop put it in their paint oven and after a few hours quite a hard coat had built up, but it was just possible to scrape through the coat with a fingernail. Basically it looks as though it remains flexible underneath for a long time, which is good for protection, but gets a harder skin quick under the right temperature conditions. If you want the DIY version to harden up quickly you should put it in a oven, or do it in very hot weather.
For the bongo much of the underfloor is away from direct pressure from road water, except the wheel arches, where I would either have a body shop do a quick harden job, or paint on one of the underbody seals which are chip resistant.
