lack of drive when pushed hard
Posted: Wed Jun 27, 2007 8:31 pm
by B king
Hi, All This is my first post the old bongo is a little poorly. Goes fine if i'm gentle with her but when i put my foot down the kick down occurs, but the drive feels as though i've hit a rev limiter and black smoke pours out !! any suggestions.
Posted: Wed Jun 27, 2007 8:43 pm
by Harry
Not sure about the black smoke but performance wise it sounds like a clogged fuel filter.
good luck
H
Posted: Wed Jun 27, 2007 8:46 pm
by B king
Thanks will get it checked out !
by dreamwarrioruk
check the little filter under the banjo on the top of the injector pump. fiddly devil but usually get clogged up. black smoke usually means fuel problems ie
its getting starved of fuel
Posted: Wed Jun 27, 2007 9:02 pm
by B king
All sounds probable as she was running fine then suddenly wouldn't pull at all max speed about 50 mph then things slowly improved,and she is quite drivable but struggles to get above 3500 revs
Posted: Wed Jun 27, 2007 9:12 pm
by dreamwarrioruk
ours changes gears at 3500rpm, with foot flat to floor it changes at 4000rpm. is it change gears ok, also it sounds daft have you checked the air filter or that the intake isnt blocked, this happened to ours and i found a spare bottle of water had got stuck over the air intake under the bonnet, no power over 2500 rpm when putting foot down, didnt do it when gentle acceleration.
Posted: Wed Jun 27, 2007 10:23 pm
by RobnKathryn
Also check that the big black plastic air hose hasn't worked loose at the point where it meets the curved metal junction piece to the right of the inlet manifold. This can be seen by lifting the drivers seat and looking top left and back a bit!
If you get a sort of sucking noise on acceleration, then this is may well be the problem.
This wouldn't account for black smoke though I'm afraid.
Rob
Posted: Wed Jun 27, 2007 10:40 pm
by moonshine
I would have thought that black smoke indicated excess fuel, so I wouldn't expect the fuel filter to be blocked. More likely the air filter, or something obstructing the air intake.
Posted: Thu Jun 28, 2007 7:44 am
by B king
I'll do some checking of the things suggested,but my feeling is i need a bongo person to take a look for me, is there any bongo specialists in the essex area.
Posted: Thu Jun 28, 2007 11:40 am
by RobnKathryn
Just re-read my post , and realised I said look top left and back a bit....well i meant top right and back a bit!!!!.........Sorry
Posted: Thu Jun 28, 2007 12:48 pm
this thread is called
I suddenly thought - yep, that sounds just like me!
Mike
Posted: Thu Jun 28, 2007 1:43 pm
by B king
HE HE HE !!! thanks Mike
Posted: Sun Jul 01, 2007 8:59 pm
by bongoing-mad-simon
hi b king
had same problem last september its a small filter in the fuel line banjo (fuel pump end) its no bigger than the tip of your small finger you will need a pair of tweesers to get it out (i thought it was my turbo but was this instead)cleaned it and the problem was solved instantly .good luck
__________________
simon
I'm bongoing mad R U?
