lack of drive when pushed hard
B king
Post by B king » Wed Jun 27, 2007 8:31 pm
:shock:Hi, All This is my first post the old bongo is a little poorly. Goes fine if i'm gentle with her but when i put my foot down the kick down occurs, but the drive feels as though i've hit a rev limiter and black smoke pours out !! any suggestions.
Harry
Post by Harry » Wed Jun 27, 2007 8:43 pm
Not sure about the black smoke but performance wise it sounds like a clogged fuel filter.
good luck
H 8)
http://watcherswildlife.co.uk
B king
Post by B king » Wed Jun 27, 2007 8:46 pm
Thanks will get it checked out !
dreamwarrioruk
Post by dreamwarrioruk » Wed Jun 27, 2007 8:46 pm
check the little filter under the banjo on the top of the injector pump. fiddly devil but usually get clogged up. black smoke usually means fuel problems ie
its getting starved of fuel
B king
Post by B king » Wed Jun 27, 2007 9:02 pm
All sounds probable as she was running fine then suddenly wouldn't pull at all max speed about 50 mph then things slowly improved,and she is quite drivable but struggles to get above 3500 revs
dreamwarrioruk
Post by dreamwarrioruk » Wed Jun 27, 2007 9:12 pm
ours changes gears at 3500rpm, with foot flat to floor it changes at 4000rpm. is it change gears ok, also it sounds daft have you checked the air filter or that the intake isnt blocked, this happened to ours and i found a spare bottle of water had got stuck over the air intake under the bonnet, no power over 2500 rpm when putting foot down, didnt do it when gentle acceleration.
RobnKathryn
Post by RobnKathryn » Wed Jun 27, 2007 10:23 pm
Also check that the big black plastic air hose hasn't worked loose at the point where it meets the curved metal junction piece to the right of the inlet manifold. This can be seen by lifting the drivers seat and looking top left and back a bit!
If you get a sort of sucking noise on acceleration, then this is may well be the problem.
This wouldn't account for black smoke though I'm afraid.
Rob
moonshine
Post by moonshine » Wed Jun 27, 2007 10:40 pm
I would have thought that black smoke indicated excess fuel, so I wouldn't expect the fuel filter to be blocked. More likely the air filter, or something obstructing the air intake.
B king
Post by B king » Thu Jun 28, 2007 7:44 am
I'll do some checking of the things suggested,but my feeling is i need a bongo person to take a look for me, is there any bongo specialists in the essex area.
RobnKathryn
Post by RobnKathryn » Thu Jun 28, 2007 11:40 am
Just re-read my post , and realised I said look top left and back a bit....well i meant top right and back a bit!!!!.........Sorry :oops:
Post by mikeonb4c » Thu Jun 28, 2007 12:48 pm
this thread is called
I suddenly thought - yep, that sounds just like me!
Mike 8)
B king
Post by B king » Thu Jun 28, 2007 1:43 pm
HE HE HE !!! thanks Mike
bongoing-mad-simon
Post by bongoing-mad-simon » Sun Jul 01, 2007 8:59 pm
hi b king
had same problem last september its a small filter in the fuel line banjo (fuel pump end) its no bigger than the tip of your small finger you will need a pair of tweesers to get it out (i thought it was my turbo but was this instead)cleaned it and the problem was solved instantly .good luck
__________________
simon
I'm bongoing mad R U?
