Post
by timhum » Wed Jun 27, 2007 8:28 pm
Yup, that's right. There are no wires for spots included as standard. The relay wiring is pretty straightforward though. If you need help someone will come up with a circuit or find one on 'tinternet.
Basically though, you need to identify the wire that goes to either existing spotlight, Scotch block a wire from it to your new switch on the dash, out of that switch to the relay coil, the other coil connection goes to chassis.
Take a fused feed of 12 volts from the battery (simplest) and feed one of the relay connectors, the other relay connector goes to both lights. I used a separate wire for each light.
Job done. Usual wiring precautions apply, ie be wary of sharp metal edges which could cause abrasion, choose a suitable fuse and wire gauge for the lights.
Hope this helps or if you knew this already, apologies, though someone else might use it someday.
Tim
