MOT & fog light
Posted: Wed Jun 27, 2007 5:37 pm
by francofontain
Hiya folks,
Do I need a rear fog light to pass the MOT? It was mentioned in an earlier post but just for peace of mind I want a get definative answer. Mine hasn't got one fitted but does have the switch (which blows the fuses of the dash and rear lights when selected) so I would assume it has had one at some point. Or do they come fitted within the rear light cluster? And breath! :lol:
Franco
Posted: Wed Jun 27, 2007 5:43 pm
by haydn callow
Yes you do need to have one. You can either fit one in or under the rear bumper or use one of your reversing lights with a red bulb. (not so good.
Sounds as thougth you had one in the past and maybe the wires are shorting, trace them from the switch and all will be revealed.
Posted: Wed Jun 27, 2007 6:08 pm
by David Edwards
If you aint got one Franco, how has it passed previous tests, weird, unless it has fallen off.
Posted: Wed Jun 27, 2007 7:07 pm
by alant54
Seems to me that if it has passed previous mot tests and there is a switch for one that it may have been one of them dangly down ones which has been demolished at some time.......if you use the fantastic search engine you will find a few topics on how to fit one in the rear bumper....can't remember who posted it...... :wink:
Alan
Posted: Wed Jun 27, 2007 8:21 pm
by daveblueozzie
bigdaddycain posted how to get rid of your dangly
Posted: Wed Jun 27, 2007 9:03 pm
by francofontain
Ta everyone
Thought it might :cry:
Didn't have one when we bought it last year so never really thought anything of it. Ah well another job to add to the growing list! :x
Ta again
Posted: Wed Jun 27, 2007 10:57 pm
by David Edwards
It just seems strange that if it presumably had an mot last year before you bought it, then..where was the fog light and where has it gone, you may find some wires dangling under the back then if it has been knocked off, I can't see anyone fitting one for the mot and then being so mean as to remove it prior to sale, if there are dangly wires they may be touching and that is why the fuse blows when you press it. Just a thought, happy motoring.
Posted: Fri Jun 29, 2007 1:43 am
by bigdaddycain
Hi Franco,
yes you will need a rear foglight(s) of one kind or another to see you through the m.o.t.
I suspect you had a "dangly" fitted at some stage, and these are notoriously easy to snap off :roll: (usually when the cable at the jetwash gets wrapped around it)
You will probably discover that the cables have been taped up out of the way in a hurry,and the bare ends of the cables are touching each other, or,the power cable may be taped to the body of the bongo underneath :shock: That'll explain the electrical short when you hit the switch.
I changed the "danglies" to these neater flush fitting items.
(my fogs are used as extra reverse lights 99% of the time,i keep red bulbs in the glovebox for m.o.t's etc.)
Posted: Fri Jun 29, 2007 9:27 pm
by francofontain
Its puzzled me :?:
And less about your danglies Big D!!!!
I'm defo going for the flush look just have to figure out the rest :roll:
Ta again.
Posted: Sat Jun 30, 2007 2:31 am
by bigdaddycain
I,m happy to say that i gave my danglies the chop :shock:
No more embarrasing instances of one of em dragging along the floor on the way home :wink:
Posted: Sat Jun 30, 2007 3:45 pm
by francofontain
:lol:
That must come with age!!!
Posted: Mon Jul 02, 2007 10:36 am
by bigdaddycain
AND experience :wink:
