How much ATF do I need ??
Post by haydn callow » Wed Jun 27, 2007 2:51 pm
Just about to drain my autobox. How much fluid do I need to get ? Any recommended types ??
westonwarrior
Post by westonwarrior » Wed Jun 27, 2007 3:02 pm
4 litres but may be 5 according to a recent thread
Post by haydn callow » Wed Jun 27, 2007 3:03 pm
Thanks for that. Bloody good thing this forum.
Lewy
Post by Lewy » Wed Jun 27, 2007 8:25 pm
I did this at the weekend - pump method fnaaaar - and took out 3 3/4 litres and put back 4 litres. Have to say muuuuuch smother on the gear changes and no audible clunk which prompted the change.
Have to say I jacked up the rear on alternative sides and got more out with the pump - really do think I got as much of the oiul out that I could with this method.
Post by haydn callow » Wed Jun 27, 2007 8:30 pm
Lewy...what sort did you use and have you a name for it ? where from ?
RobnKathryn
Post by RobnKathryn » Wed Jun 27, 2007 10:55 pm
Haydn
The best pump for this job is a Pela 6000, guide price about £30 + postage. It can be used for engine oil changes as well. It holds 6 litres.
Do a search for 'Pela' on this forum and there's a recent post with lots of info.
There are cheaper syringe type arrangements, but I think false economy.
Rob
Post by haydn callow » Thu Jun 28, 2007 9:42 am
Thanks for that. I do have a sucker pump.
Lewy
Post by Lewy » Thu Jun 28, 2007 9:04 pm
http://www.machinemart.co.uk/shop/produ ... uction-gun
Someone else's tip - nice cheap option - dead easy to clean, not sure if I would do a full engine oil change with it though but did the atf just dandy.
Lewy
Post by Lewy » Thu Jun 28, 2007 9:06 pm
You do need to go to B and Q and get a slightly longer tube though - cost about £1.60.
