Do you have these speakers?
and Griffin's request for further info when available...
We picked up our Bongo on Saturday, at long last. Generally very happy with it, but that's another story.
Anyway, on the audio front my findings so far are much as suspected, i.e.:
- The front speakers are 150mm diameter circular (6") which is an uncommon size but some component and coaxial speakers are available which will fit directly into the standard mounting pods, albeit with new holes being screwed into the plastic (just use self-tappers). Mounting depth is severely limited (under 2 inches) without cutting away plastics from the rear of the door panel and messing about with extra MDF in the mounts, maybe even cutting away some metal from the door itself. I’m expecting this to be the biggest pain in the whole deal.
- The rear speakers are 150mm x 200mm (6"x8") which is an unusual size but often used by Ford and Mazda so again there are some speakers available e.g. the Pioneer TS-H683s I bought off ebay. Mounting depth is not an issue but speakers with very large diameter magnets may cause an issue.
- All the factory speakers are nasty paper cone jobs rated at 25W DIN. Highly chuckable IMO. The factory 6x8s weigh 400g each, the Pioneers 1030g. Likewise the factory wiring is horrible thin stuff and should be replaced with something meatier (I'm only bothering on the front though as I'm lazy).
So far I have removed both rear panels (we have a split third row which makes it fairly easy) lined the body panels immediately behind the speakers with some B&Q sealing tape (cheap vibration damper). The fixing clips from the trim panels do indeed ping off all over the place and need careful herding. The trim panels themselves come with foam padding to stop them rattling around too much and there is a bit of sound proofing on the wheel arches and lower part of the body panels; bit of a token effort though.
I also did a bit of basic "winterizing" by lining all accessible panelling with left over Thermawrap that was used to make some silver screens, which should also help reduce vibration.
The screws mounting the rear speakers to their metal frames were quite corroded in. I suggest you give them a good dose of WD40 and leave them for an hour or two before going near them with a screwdriver else you run the risk of messing the heads up and having to drill them out.
My plans changed when I realised the fronts were 6" circular and the rears 6"x8"; I've dropped the Pioneers in the rear and ordered a pair of Infinity 6010i components from ebay for less than half RRP (I think someone else on BF went for the same). These are good speakers but apparently a little bright in the high end for some tastes but this will probably suit the Bongo quite well as it's quite a noisy vehicle when cruising. I'm not going to bother fitting the Kenwoods as they're too big for the area in the roof where the roof vents are.
I'm very pleased with the Panasonic CQ-C5303N head unit. It has a host of good features and a remote for under £90 inc. P&P. Some of the features I didn't know about but was pleased to find:
- 4x20W RMS (drives the Pioneers fairly well considering)
- 2 pairs of pre outs, front and rear
- aux in (just get a 1.5mm mini jack to phono lead and plug it in here to connect an -external MP3 player)
- lots of SQ options (+/-12dB at loads of frequency points, 5 savable presets, several default ones, basically a nice EQ)
- selectable colour display red/green
- multi-level tiltable panel (fairly useless in a Bongo but fun!)
I’ll add some pictures later.
For other audio related info see these threads:
Speakers..........help,please
Rear speakers.....
Door speakers
Just fitted a great inexpensive CD/tuner head unit
Connecting stereo to leisure battery with switch accessible from rear
standard ISO wiring diagram (external link)
More on ISO wiring (external link)
and the members' audio fact sheet (which can of course be updated with any of the info in this thread if Ian thinks it's useful). The best car audio forum is talkaudio
Cheers,
Paul (ICB)
       Pete
