Coolant
JTR
Coolant
I've just returned from a fantastic trip in our Bongo to the Outer Hebrides. The trip was not without the odd hiccup however! We cruised up to Skye without any problems at all. Toured around the island for a couple of days and then were heading to the ferry when we started to overheat terribly. I stopped straight away and popped the bonnet to find that the water was boiling out through the expansion tank. Having let the van cool down for a good thirty mins, we topped up with water to the right level and set off again only to have the same happen to us again 5 mins later. At this point we called GreenFlag (thank god we had mobile reception!) We were put on a wagon and taken to the nearest garage were they looked at it and said that a couple of belts had slipped off - the 2 attached to the alternator - this was causing the van to overheat - at least it wasnt the head gasget! The parts came in the next day and we were thankfully sent on our way.
However, the coolant has only been filled with water. I now need to replace half of this with the correct anti-freeze. Can I allow excatly half of the water to drain out and then replace with anti-freeze? - or do I need to drain the whole lot and start again?
Any help/advise related to coolant and the replacing off greatly appreciated!
Thanks,
Thanks,
- Peg leg Pete
- haydn callow
I would test the strength of the coolant. Drain about a pint by releasing the Radiator cap. Top up the expansion tank to the full with neat antifreeze. Run the Bongo fof a couple of days then test again till you get the reading you want. You can get a cheap tester in Halfords ao ask in any garage. They will do it for you,
- haydn callow
JTR
- haydn callow
JTR
Vanmanerik
Top up with coolant
Ermmmmmm.
Drain about a pint out of the expansion tank and then fill it up full and run it for a day??????
Where is the expanded water/antifreeze going to go when the engine warms up? Out of the tank................ is antifreeze that cheap?
Why is there a max and min mark on the expansion tank, if you fill it to the min level then usually when the engine is warm it will rise to the max mark, leaving some room in the expansion tank.
There would be no harm in draining 5 litres of coolant off and replacing it with 5 litres of antifreeze. You will end up with a stronger solution anyway doing it this way so no need to buy a strength tester.
Its no big deal bleeding the system if your cooling system is free from obstructions, the radiator is clear and the thermostat is working correctly and your coolant pipes are not leaking, if you are worried then flush the system, check that the radiator is not blocked, check the thermostat, check your coolant pipes, if all OK then refill with 50/50 water antifreeze and all will be well.
JTR
Right - I'm still a little confused as to how you actually let some water out of the system! If I undo the cap on top of the radiator and then undo the one on the top of the expansion tank - then water will flow out of the top of the radiator? I then replace the water lost with antifreeze into the expansion tank?
Cheers,
JTR
Cheers,
JTR
Vanmanerik
Drain coolant.
As you face the van from the front there is a drain tap on the left hand lower side of the radiator.
Or if you want a fast uncontrolled drain then remove the lower coolant pipe from the radiator.
JTR
basically yes.JTR wrote:Right - I'm still a little confused as to how you actually let some water out of the system! If I undo the cap on top of the radiator and then undo the one on the top of the expansion tank - then water will flow out of the top of the radiator? I then replace the water lost with antifreeze into the expansion tank?
Cheers,
JTR
but like vanmaneric says, if you are going to change the coolant totally (if you think/capable of doing it this way) just unclip the bottom hose of the radiator and let it run out, but if you just want to top it up, empty the expasion tank as said, replace cap on radiator then fill the expansion tank up with neat antifreeze.
btw, how much water did you fill your bongo back up with?
- Peg leg Pete
Pete
