hes giving me a good service!!
caznsue
Post by caznsue » Fri Jun 15, 2007 1:57 pm
thanks ian for sorting me out!! he he
just a quick question, im having a big service done next week,
can i tell you what i got and you tell me if im missing anything......
air filter, oil filter, fuel filter,
cambelt and sping and the tensioner.......
engineer does the oil....does it need anything special....
is that me lot.....
he said not to get glow plugs unless starting is a problem, ....well it is a little reluctant....bit chuggy and bit of smoke.....
got the bits from bongo bits but just wanted to make sure that i have everything, as travelling up north in it in 2 months.....
cheers in advance
caz 8) 8) 8)
smartmonkey
Post by smartmonkey » Fri Jun 15, 2007 2:45 pm
I would do the glowplugs and supply the oil (5W30). If he's doing the cambelt you might want to do the ancilliary belts at the same time.
And if you don't know the history change the gearbox and axle oil without fail.
caznsue
a good servicing,,,,
Post by caznsue » Fri Jun 15, 2007 2:47 pm
what are the other belts...........
sorry woman driver and all that........
any ideas on the other oils that i need or are they all standard....
francofontain
Post by francofontain » Sat Jun 16, 2007 7:14 am
Out of interest where abouts are you going for your service?? As I only live 10 miles away and been travelling to Reading for my services. :x
Franco
caznsue
service
Post by caznsue » Sat Jun 16, 2007 8:28 am
hi there, ive sent you a message with all the details,
hope it helps
caz
jimsmimm
Post by jimsmimm » Sat Jun 16, 2007 11:31 am
dont forget ATF fluid.... :lol:
caznsue
servicing
Post by caznsue » Sat Jun 16, 2007 11:50 am
is that rude!!! or are you being serious, if so whats that.....
and the other belts someone mentioned,
i have cambelt and fanbelt......is that it........
dont go getting technical on me......... im a woman,.....
need 10 men really.....one for diy, engineer, decorator, plumber, plasterer, electrician, domestic cleaner, gardener, car washer and a rich one....why should we only be allowed one man at a time..... he he :o
jimsmimm
Post by jimsmimm » Sat Jun 16, 2007 4:14 pm
ATF....automatic transmission fluid..... worth while having done whilst its in......as long as you have an automatic that is..... :lol:
maxheadroom
Post by maxheadroom » Sat Jun 16, 2007 5:36 pm
don't forget the coolant, 50/50 water and antifreeze.
Keep the Faith
