However, after about 1.5 hrs of comedy, the duracells were exhausted...
How can I connect the DAB to the leisure battery circuit, bearing in mind that the power requirements are 9V/1200mA (I've looked at some cigar lighter plug in adapters, but they only seem to be rated at 800mA...).
Is it as simple as connecting a resistor, in series, to bring the voltage down ? If so, can it be calculated from Ohms Law ?
Help ...
