I noticed a few days ago that my power steering felt a little heavier, but wasn't sure so put it
down to "just my imagination". A day later I had a slight squeal from one of the belts, but only
very slight & only for about 2 mins from a cold start.
Yesterday, I was on a large roundabout with a slight right lock on, I came to exit the
Roundabout & it felt as though someone had switched the Power Steering off for about 0.5 of a sec, it was fine after this. Seemed like lazy power steering
Almost felt like a Jam, but didn’t require much forces to move the wheel. When parking, steering seems normal, maybe a bit heavier not sure
really, no belt squeals at all anymore. Checked the PS fluid level, which is at Max, crawled
underneath, no visible leaks from steering rack. In fact it looked very clean
The PS reservoir pipes go to a unit below it, I guess this is the PS Pump? one of the pipes has a
bit of oil on it, but it was pretty solid, not what I would call a leak, seems as though its been
like that for years.
Its typical, just started the summer camping trips & I have a problem. I’m due to go to Ilfracome
this weekend, so I’m obviously keen to try & fix it.
Anyone have any thoughts?
Stuart
