Rear Air con
caleybongo
Rear Air con
Hi Folks,I have looked through previous air con subjects but I'm having no luck,The rear air con was working fine,but when I now select rear there is nothing(digital type),the front air con is working.The system was recently re-gassed.Is there a fuse for the rear air con?any suggestions !
Naughtydog
have you checked for switches or buttons on the front control panel that says "rear",
mine is only manual, and i have a switch to the right of the steering column. when switched my rear blowers will then be able to be controlled from the rear, BUT only if the front is switched on.
in conclusion my rear only works when the switch is made and the front blower is selected to at least 1 on the dial.
hope this helps
hope this helps
Mark & Shelly
Just wondering if this previous post might help - in particular Waycars little known tip.
http://www.igmaynard.co.uk/bongo/forum/ ... rear+vents
I never knew that either, so give it a try.
