Not sure if this is anything to worry about, but, when elevating our Bongo roof, the beeping alarm noise doesn't stop – even when it appears fully elevated. It won't go up any further, put it that way. Obviously, the only way to turn the beeping off is by turning the key in the ignition, but then what if you want to listen to the radio? There's that beeping again!
Any ideas? Could something be jammed up there? Roof seems fully elevated.
Neil
PS: planning 3 weeks round Europe in our Bongo soon, so will be back in touch soon....
Beeping won't stop when roof is elevated
portybongo
- alphabetter
The switches that detect when the roof is fully raised require it to be right at the very top of the movement before they trigger. Once you've got the roof up keep the "up" button pressed and give a firm push to the top centre of the roof. Beeping should stop!
You may need to check the lubrication of the roof mechanism if it is a frequent problem.
MAZABON
roof
lubrication is probably needed, i had this problem with my roof but resolved it by going up a bit- down a bit- up a bit- and so on, until it made it all the way up, i think the reason for mine being sticky was not being raised for ages ie all through the winter
Keswick
jimsmimm
smartmonkey
pippin
