SCAVENGER FAN
alldav61
SCAVENGER FAN
Post by alldav61 » Mon May 28, 2007 9:33 pm
HOW DO I CHECK TO SEE IF MY SCAVENGER FAN IS WORKING
Peg leg Pete
Post by Peg leg Pete » Mon May 28, 2007 10:11 pm
You should hear it come on, if not lift up driver seat, you should find sensor on top of engine behind the handbrake, unplug clean contacts and re -insert. Scavenger fan will come on when engine bay becomes warm :wink:
Image Pete
dandywarhol
Post by dandywarhol » Mon May 28, 2007 10:22 pm
Put a paper clip into said contacts - that'll bypass the sensor and the fan should come on. :)
paul9
Post by paul9 » Wed May 30, 2007 6:27 pm
Just been testing my scavenger fan,the sensor is a black plug under centre consul,just unplug it, switch ignition on and it should start to work after a few seconds,your heater plug light will probably flash on/off until you plug it back in to the sensor,i didn't need to use a paper clip on mine,so sensor must work opposite way :D
dandywarhol
Post by dandywarhol » Wed May 30, 2007 6:52 pm
Ah.......good one Paul..............got that one wrong eh???? :oops:
paul9
Post by paul9 » Wed May 30, 2007 7:04 pm
dandywarhol wrote:Ah.......good one Paul..............got that one wrong eh???? :oops:
only found out by accident,had it unplugged and was looking round for something to push in plug to short it ,and felt this draft ,at first i thought it was radiator fans,but then noticed it was scavenger fan :D :D :D
dandywarhol
Post by dandywarhol » Sun Jun 03, 2007 11:09 am
I thought I'd try the scavanger fan test method - unplugged the sensor wire and the fan DIDN'T come on :? ..........I connected the wires with a paperclip and the fan came on - removed the paperclip and the fan stayed on :shock: until I reconnected the terminals to the sensor...................weird things these Bongo electrics :roll:
