Water pool when Bongo parked
ParkerNorris
- Bongonaut
Being ever vigilant to catch an overheating problem early, I've noticed a small pool of fluid under Mungo the last couple of days. I'm pretty sure it's aircon 'condensation', but would like a second (and third, fourth, etc) opinion.
I noticed it first the other day when Lara parked up at the end of the day. Within an hour the pool had evaporated. Yesterday, I went and had a look as soon as she parked up. There was a pool, and a drip. I tasted it, and it was water (ie not coolant). The pool is dead centre between the front wheels. The drips come from the black plastic moulded box, the one that sits below the ventilation air intake that has the cable mechanism (which I guess are the heater/ventilation controls).
I've only noticed it the last couple of days, which is coincident with running the aircon.
So, is this 'normal', or do I have to investigate further ?
Paul & Lara
It's 'Our' Bongo; not his, not hers...
- daveblueozzie
ParkerNorris
- Bongonaut
Colin Lambert
It is aircon condensation. If you catch it in a bottle before it hits the ground you can use it to top up your battery. (condensed water).
The first time (before I owned a car with air-con) I saw this puddle was in Florida and I made a right tit of my self. stopped oat traffic lighs on a 6 lane highway I noticed this ever increasing puddle forming under the car next to me. I yelled 'cos his window was up(!) and when he had wound it down I said in my best Brit accent , "I think your radiator is leaking!"
With a bored expression which said 'Stupid Limey', he said "It's the aircon!".
Did I feel a plonker or what!
OY! I'VE JUST NOTICED.WHO'S SHRUNK MY AVATAR?
But if really worried, who not keep the aircon off for a suitably lengthy period and see if you no longer notice little puddles underneath. I'm very stingy in my use of the aircon in order to avoid higher fuel consumption, and I've missed having it on much so far this year. With teh wind deflectors on most Bongos, Its lovely driving along with the window open, even in rain (up to a point!).
Mike
Mike
ParkerNorris
- Bongonaut
Use it or lose it Mike!! - aircon should be used regularly, or the seals will dry out and the gas escape.mikeonb4c wrote:But if really worried, who not keep the aircon off for a suitably lengthy period and see if you no longer notice little puddles underneath. I'm very stingy in my use of the aircon in order to avoid higher fuel consumption, and I've missed having it on much so far this year. With teh wind deflectors on most Bongos, Its lovely driving along with the window open, even in rain (up to a point!).
Mike
ParkerNorris
- Bongonaut
trevd01
Have you measured what difference putting the aircon on makes to your mpg?francophile1947 wrote:Use it or lose it Mike!! - aircon should be used regularly, or the seals will dry out and the gas escape.mikeonb4c wrote:But if really worried, who not keep the aircon off for a suitably lengthy period and see if you no longer notice little puddles underneath. I'm very stingy in my use of the aircon in order to avoid higher fuel consumption, and I've missed having it on much so far this year. With teh wind deflectors on most Bongos, Its lovely driving along with the window open, even in rain (up to a point!).
Mike
I have. None that I can detect. Our Bongo returns 24-26 mpg tank after tank. Long journey, short journeys, hot weather, cold weather.
- haydn callow
