Alarm instalation
Gozzy
Alarm instalation
Have just bought an Alarm for the Freda
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... &rd=1&rd=1
Now have never instaled an alarm before so was wondering if anyone thats done it, where's the best place to install it?
Under the glove box, in the engine compartment or under the bonnet
Anyone got some pics ?
Scott & Gillian
Having never before attempted to fit an alarm, I would also be very interested in a 'muppets' guide to fitting one of these!
I'm a collector of random things. Anything. But not glitter, which is nasty.
www.random-things.co.uk
etihsbog
I fitted one of these a couple of months ago, but chose to fit the microwave sensor in place of the dual zone shock sensor. I also had to fit the 2 Wire Slave Door Motor / Solenoid / Actuator to enable the central locking. Fitted the main unit inside Centre housing toward your feet. Also coupled the sounder to my air horns through a seperate relay, but had to set the alarm to silent arm/disarm ( air horns Blaring at 5.30 when I turn alarm off not good). Did not bother with remote start but aim to do so one day. Took approx 2.5 hours from start to finish, but thats with me being an electrician would expect it to take maybe an hour or two more, depending upon how confident you are with electrics. Will try and get some photos done in work tomorrow but would say it is quite an easy job, just take your time and check all your joints etc. They seem like they are a good alarm, not had any false alarms in 2 months (maybe thats because it doesnt work). Also it is worth fitting the override push button in case of fob failure or losing it. Any questions just ask
etihsbog wrote:I fitted one of these a couple of months ago, but chose to fit the microwave sensor in place of the dual zone shock sensor.Also it is worth fitting the override push button in case of fob failure or losing it.
chose to fit the microwave sensor in place of the dual zone shock sensor?
i have both, splice the wires together. nobody will be towing my bongo away without me knowing.
you dont need one, i guess you havent read your manual.
testrun00
I like you the way you think PMSL
. But I must admit you lot got me interested in buying one now!!
I was also thinking of getting a 4 window closure unit and taped 1 output up ,2 to the windows and the third output to the sunroof,For thou those who have tintops.Should work afterall it's just a big electric window....
etihsbog
etihsbog
My microwave unit is a single piece of kit and is hidden away. The sensors on the pillars are ultra-sonics, two different types of sensor. The microwave basically fills the car with an invisible bubble, if the size of the bubble changes ( window broken / door open ) this triggers the alarm. The ultra sonics work by something interrupting the path between the two sensors.
