condensation in fog light
- AndAndDen
Fog light bulb blown, due to condensation or rain in the fog light fitting. When i took the rubber off the back there was an accumalation of water in the rubber ,Does this mean the unit is caput ,or can it be repaired and resealed
. The other fog light is ok .
Get a Life ,Get a Bongo. !!!
- You've Been Bongod
hi andandden my ofside fog light was the same so i changed the bulb and siliconed the gator back over the fog light
hey presto water tight
you've been bongod
you've been bongod
- AndAndDen
bigdaddy no cutout or anything in the plastic. So rather than damage it i decided to take the fitting off the front to get a good look at it. Took the lamp and the lamp holder out and gave the lense a good clean from the back of the fitting.Looks alot better now. Cheers Andy
