I was out cleaning t'bongo today with the ignition on but not running so I could listen to the radio , when I turned the radio off there was a buzzing noise ( sounded like it was coming from near the fuel tank) which I guess has been there in the hr or so I was outside. Still enough power for the radio but none to start. I have the std winter 2 x batteries so it must be some drain to take them down in an hr.
I will take this to the garage but wondered if anyone had had any similar problem - not long drains like what I have been able to find in the searches - but a rapid drain.?
The batteries are fine, voiltages are all ok and now the van has been running (jump start) batteries are back up and start her no problem. Also the noise has now gone so whatever the problem is is it intermittent (Joy!)
Thanks for any help,
Russ
