Hoping for some advice / reassurance from the electronics experts out there.
I have a PMS 34 power management system fitted in my converted van, but I'm not sure if it is wired correctly.
There was originally a wire running from the PMS unit to the Live feed on the alternator (this was fitted by the company who originally converted the van). However, this set up was drawing current from both batteries when the engine was switched off - irrespective of which way the battery selector switch on the PMS was pressed.
I know that on some vehicles, the alternator is only live when the ignition is switched on, but in the Bongo the alternator is always live, so I made an assumption that the connection to the alternator was supposed to be an on/off feed to a relay, and I've now removed the alternator connection and re-routed it to an ignition live in the dashboard fuse box.
This now allows me to select which battery is used to power the fridge etc. when the ignition is switched off (i.e. current is drawn from just the leisure battery when "van" is selected and just the vehicle when "car" is selected).
When the ignition is switched on, both batteries are re-connected in parallel, allowing the vehicle battery to charge the leisure battery when the engine is running.
First of all - can anyone tell me if I've missed a trick, and my modifications are wrong
Secondly - If what i've done is correct - I wonder if anyone else out there has their PMS wired up to the alternator and are risking a flat starter battery in the morning
