Overheating Bongo... My Cup/Expansion Tank runneth over
patmckenna
Post by patmckenna » Sat Apr 21, 2007 12:33 am
Hi Folks,
The great overheating debate seems to have died off a little but I need to resurrect the topic for a few minutes with a cautionary tale. I've had overheating problems in the last few weeks and have received excellent advice on this forum. Having had a few days away, I decided to get on with the suggested procedures to diagnose the problem.
My various one-man band garages in Blackburn didn't do dye-testing, but I managed to get a chap to do a pressure-test. He did the procedure there and then. There was no drop in pressure and he couldn't find leaks anywhere on the system despite a minute search with both seats up and torch underneath etc.
When I explained all the 'bleeding' problems we were having, he suggested we give it a quick try at bleeding the system whilst it was under pressure. I manned my marigolds and the bleedhose and he didn't bat an eyelid. Furthermore, he checked the water level in the expansion tank and repressurised the system when necessary. By the time we had bled, 'capped-off' and refilled four times, we were sending out liquid only, with no sign of any remaining air bubbles. I have to say I was very cynical and told him so. He said not to worry - if it didn't work I was to come back and he would use a vacumn process instead. I expected to return within the hour - but I am astounded to say that that was four days ago and the needle has read eleven o'clock whenever I've taken the beast for a spin up and down the hills of Lancashire.
The cautionary bit is as follows. When I was tackling my overheating problems a few weeks ago, I carefully followed all the bleeding procedures as per the manual and the forum - but - on reflection I may have made a fatal error. I was frantic to avoid re-introducing air into the system via the expansion tank when topping up after a satisfying bleed, so I may well have over-enthusiastically filled the expansion reservoir. At the time I rationalised that any excess liquid would simply drain off as the system became pressurised. Something tells me that by leaving little or no air in the expansion tank, I perpetuated the cycle of overheating. I blush to add that when I took the beast for test drives on those occasions, I stopped after every two or three mile 'up hill and down dale' loop, bled the system again, and filled the expansion tank to compensate for the loss at the other end...
What have I learned from this? I've just ordered a £2.37 Draper 1.8M Syphon Pump to syphon off excess water in the expansion tank when I attempt to top up in the future. I know real men 'suck and see' but I was traumatised at an early age whilst trying that technique with petrol... I have two lollipop sticks superglued together to create an eight inch dip stick with a min line and max line carefully drawn with a permanent marker. I never knew what 'anorak' and 'anal-retentive' meant until now... Also, being very impressed with the pressure tester, I popped on to E-Bay and managed to get my hands on one by leaping in with 10 seconds to go. There is no room for passengers in the Bongo - It's full of 5 litre bottles of water.
I am acutely aware that my investigations into the overheating problems with the Bongo are not over yet. I want that dye-test, and I want to have the radiator pressure tested. I've been at this point before, where I have managed to get back to full operational mode, only to fall foul of high temperatures a few weeks down the line. I'm interested to know whether pressure or vacumn bleeding is successful.
Well, there we have it, lollipop sticks and the highs and lows of an overheating Bongo. Who needs television.
Pat
Post by bigdaddycain » Sat Apr 21, 2007 12:41 am
Finger's crossed pat :wink: Was the lollypop sticks glued together a tongue in cheek comment pat? Why not just look at the header tank to see the level? Or am i missing something? :? I hope its sorted for you :wink:
patmckenna
Post by patmckenna » Sat Apr 21, 2007 12:56 am
Hi Big Daddycain,
Thanks for the post. The lollipop dipstick is genuine. My expansion tank is gravely discoloured and I cannot gauge the level of water in it. You musn't snigger, but being fivefootnuthin' doesn't help either!
Life is a bowl of cherries
Pat
pippin
Post by pippin » Sat Apr 21, 2007 9:03 am
Pat, from: I manned my marigolds and I blush plus being fivefootnothing I was beginning to form an impression of your gender.
You then shattered my illusions: I know real men
Which is all a light-hearted preamble to thanking you for an excellent advisory cautionary tale.
patmckenna
Post by patmckenna » Sat Apr 21, 2007 9:58 am
Hi Pippin
Thanks for the reply. I use yellow marigolds, they complement my grey/white beard. I did use the pink ones for a while but started to get funny looks...
Very seriously though - the gloves are just the job for the air-bleeding moments and they have provided me with an added safety layer to protect hands during steamy procedures...
Freud has just asked me to stop whilst I'm slightly ahead in case I slip.
Be good.
Pat
Vanmanerik
Overheating
Post by Vanmanerik » Sat Apr 21, 2007 11:09 am
Nice write-up on your coolant bleeding technique Pat, I hope it has cured your problem. How about letting us all know 2-3 weeks down the line if all is still OK?
My expansion tank is opaque with gung and grime, I took it off an put Fairy Liquid in it with water, blocked off the holes and put the cap on and SHOOOOOOOOOK it, when I emptied it and washed it out in clean water you still could not see through the wall! So, I got a bottle cleaning brush and brushed inside as best as I could and then washed it out and you STILL cannot see through the side so I too use a dipstick but mine is a piece of thin garden cane. :)
A few weeks ago I gave all my coolant pipes, crankase, radiator etc a good flush out, I removed as much crud as possible, I then removed my thermostat and checked it in hot water, it worked OK, I drilled a 2.5 mm hole in the thermostat and replaced it, I refilled the system and bled it - this time it bled really easily. I have run the Bongo for 2 weeks now and done perhaps 350 miles on all types of road and it has behaved very well, it tales a little longer to warm up now and the temperature guage sits at maybe 10:30 instead of 11:00 so it is running a little cooler but there is a flow through the radiator and the bottom hose gets warm now, it didn't seem to have a flow before - the bottom hose never got warm.
I am happy with this set up, I do not know if I will cause any harm in the long run bit I do feel that my chances of overheating have been minimised [-o<
timhum
Post by timhum » Sat Apr 21, 2007 11:46 am
To add to the vacuum technique mentioned earlier.....
I had the exhaust manifold studs done on my Bongo a few weeks ago and the garage was adamant that they needed to drain and refill the coolant. I impressed upon them the vital nature of what they were doing and they said they would refill using the vacuum techique. I don't know or care what it is but it worked, I left them with a copy of the "bleeding instructions" and dire warnings of what would happen if theyy mucked up.
Hey presto, it worked and all is OK, so perhaps the vcacuum method is a gooer, particularly if checked with the "bleeding hose" afterwards.
Tim
Vanmanerik
Vacuum Refill
Post by Vanmanerik » Sat Apr 21, 2007 5:09 pm
If you are interested in knowing how the vacuum refill works goto
http://www.mityvac.com/user_manuals/MV4535.pdf
Hope this helps
clogger
Post by clogger » Sat Apr 21, 2007 7:14 pm
what a cool idea
i liked it that much
i`ve one on order from across the pond
be good to see how effective it is
ECKY THUMP
the one true art form
