When I start it up there is a reasonably noticable judder then its fairly smooth (well as smooth as a 10 yr old diesel ever gets!)
But when i turn it off regardless of whether its still cold or hot I get really noticable judder.
To me it seems like worn engine mounts may cause that... but i would have thought they would give other symptoms also... ?
Its the same noise you hear when an aged lorry switches of engine....
Cos the engine is transverse the van kind of rocks from side to side as the engine stops running... defo like its swinging about too much.
Mine is supposed to have done 46k..... but im not bad at car stuff and id say more like 90k....
Any one esle had this symptom?
Pete
