Recently, most times when I lock / unlock drivers door with key, the passengers door sometimes does not. and the back door rarely unlocks Q. is some electronic switch / connection sticking?? obviously I can unlock passenger and side door with key, but not the back door, any ideas??
I supose its not connected but other problems are the drivers window wont open/close and recently the drivers mirror wont park flat, a previous sugestion for the window was the electric cable in door closing space, is it a case of peeling outer cables to find broken wire, join and tape up??
CENTRAL LOCKING
Peter Brazier
dp bradford
Re: CENTRAL LOCKING
Sorry I can't help in diagnosing the problem, but why can't you open the back door with a key??Peter Brazier wrote:I can unlock passenger and side door with key, but not the back door
- maxheadroom
- brorabongo
Peter Brazier
dp bradford wrote:
dp bradford wrote: why didn't I open back door with key?? answer, is my Bongo the odd one out!! I have no key hole to insert a key in.
dp bradford
Re: dp bradford wrote:
Wierd! Is this normal, do other folks not have a key hole?? Maybe I'm just luckyPeter Brazier wrote: is my Bongo the odd one out!! I have no key hole to insert a key in.
