Page 7 of 13
Re: Cardiff - Starting & coolant loss problems
Posted: Fri Jan 19, 2018 4:33 pm
by cutlass
please - say me what that "40 quid"? on my bongo "compression pressure" apr 29-31 kgs\sm2 (apr 30 bar)
and - you may finde only two "repair size" of pistons and ring +0.25, +0.5mm......but it is "chines aftermarket parts" - it must check carefully!
Posted: Sat Jan 20, 2018 12:27 pm
by haydn callow
No ... not the same....skimming is taking the head to a engineering shop and having a bit machined off......decking is done with a piece of plate glass, engineers blue and cutting compound. Done in situ...do a search on here and there have been a couple of posts. I think that’s right but never actually done one myself.
Posted: Sat Jan 20, 2018 12:31 pm
by haydn callow
Just searched.....decking the block......it’s all there....Simon Jones is the man to consult.
Posted: Sat Jan 20, 2018 1:17 pm
by teenmal
This is decking the Block, using emery or similar method is merely cleaning the surface.
https://www.youtube.com/watch?v=Arv03lKIKBs
Take Care
Posted: Sat Jan 20, 2018 2:13 pm
by Bob
That's the great value of this Forum.
Plus the friends, great Meets, the helping hands...
Posted: Mon Jan 22, 2018 3:10 pm
by teenmal
If you are removing the head it is normal practice to time the engine (cam belt ) After the head has been Fitted.
Take care.
Posted: Mon Jan 22, 2018 4:06 pm
by cutlass
Posted: Tue Jan 23, 2018 8:24 am
by cutlass
I hard translate-sorry///
I talk about - new head have t-piece - it is for non-turbo engine, you need use 4-piece tube
Posted: Tue Jan 23, 2018 10:21 am
by teenmal
plonkatronix wrote: Mon Jan 22, 2018 4:02 pm
teenmal wrote: Mon Jan 22, 2018 3:10 pm
Take care.
I think you missed my point, my experience tells me to place it a 'timed' position for removal to save the need to turn anything once belt has been removed... sorted now, I found the 24mm spanner seat on the cam to help move it round
Don't think so, after you remove the head you will be turning the engine to do the crowns, also the new head will be in a different position.
But it looks like you know something I don't.
Take Care and good luck.
Posted: Tue Jan 23, 2018 10:29 am
by cutlass
NOTE! on "new chines head" be leak valves, be wery bad "valves sealer" - you must decide it befor install it!!!
Posted: Tue Jan 23, 2018 5:35 pm
This is a common place for the cracks to occur;
Posted: Wed Jan 24, 2018 2:27 pm
by cutlass
if it possible - do "pressure test" again
https://youtu.be/jWakwJCO7NI
Posted: Tue Jan 30, 2018 12:42 pm
by cutlass
Posted: Tue Jan 30, 2018 2:17 pm
by TheLongRoad
Oh no, sorry sight. Hope you are not hurt, just shows how strong the Bongo is as the damage to the other car is extensive.
Posted: Tue Jan 30, 2018 2:22 pm
by Bob
Oh no!
What rotten luck.
