Silicone coolant hoses
helen&tony
Silicon hoses
Post by helen&tony » Mon Nov 12, 2007 9:25 pm
Not that bad via Royal Mail Sign For Direct Priority....very efficient....3-5 days....but Aeons over the Chrissy period
P.S. couriers are pretty good Europewide...cost a little more though...I often got high-tech bits sent Holland- England
redalan1971
blue
Post by redalan1971 » Mon Nov 12, 2007 10:12 pm
i will gladly part with some bucks for a set.
rushmon
Post by rushmon » Tue Nov 13, 2007 12:12 am
Hi Flippa,Great product!Think il be interested in a set in Blue also if they're not too expensive......got a feelin it may have to be after Chrimbo tho!!!
_________________________________
Each time i get in,it just makes Grin!!!
Post by bigdaddycain » Tue Nov 13, 2007 6:36 am
Post chrimbo for me too then methinks....Unless santa fancies sticking a hose down the chimney for me of course... :wink:
smartmonkey
Post by smartmonkey » Tue Nov 13, 2007 2:46 pm
bigdaddycain wrote:
smartmonkey wrote:A few points spring to my mind:
They need to be a good bit cheaper than Mazda to persuade me to get a full set rather than the odd Mazda one as required.
I'm quite suprised you stated the above SM :? I'd have thought that you'd have known as well as any that if one hose has/is/going to let go, then the others can't be far behind...
Granted, different hoses have different stresses, but the pressure is uniform from one hose to the other is it not? (correct me if i'm wrong, i'm no mechanic)
Flippa? Does the kit include the bleed hose?
You are quite right BigD, a full set is always best on a 10 year old vehicle. However, hoses do wear out at different rates depending on:
Contamination (they hate oil and diesel)
Clamp pressure
Operating pressure
Operating temperature
Size (big hoses seem to suffer more)
Mechanical wear
Luck of the mold/rubber batch
Amount of internal scaling
I think my hoses are in good order but I have saved two from chaffing through and one is possibly a touch firm for my liking. If a kit came along at a good price it may temp me to just change the whole lot and do a good coolant change and flush at the same time. I am blessed with a high mileage Bongo (90,000 miles) and because of this the cooling system seems to be very clean so I havent been tempted yet.
flippa
Post by flippa » Tue Nov 13, 2007 6:01 pm
cheers rushmon :wink: ...there is a way to go yet , although i was hoping to wrap them in crimbo paper :roll: ......me at the moment i feel like an expectant father ...waiting for their arrival :roll:
flippa
Post by flippa » Sun Nov 18, 2007 7:13 pm
update:hoses arrived just awaiting pick up mid - week :) ...will keep you informed :wink:
Socket Set Sue
New hoses
Post by Socket Set Sue » Sun Nov 18, 2007 7:57 pm
Well done Flippa, are you going to give a breakdown of what consists of a full set, or is it a 'full set' where every pipe is included?
I would like to be put on the list of potential buyers please, I can confirm after you have calculated and published the cost of the set.
Peg leg Pete
Post by Peg leg Pete » Sun Nov 18, 2007 8:31 pm
Well done Flippa :wink: I have sent you a P.M. :wink:
Image Pete
flippa
Post by flippa » Sun Nov 18, 2007 8:42 pm
hi sue the hoses in the set are ......15183 ( top, drivers side ,rad to steel pipe)
15184 (bottom rad hose ,passeger side)
15185 (therm to steel pipe)
15186 (top drivers side)
15277 (rad to header tank)
15261 (therm to head)
15381a(bleed pipe)
plus two i cannot identify using the schematic : so9g-61-213a heater hose
so9a-61212 water hose
pictures will help to easier i.d the hoses which i will add once i get them ...
price wise sue ...nearly there but not quite, all will be revealed in due course,
all i can guarantee is that it will be below the current price on offer for the rubber equivalent....i will also have speak to ian about a special price for the members.... :wink:
Socket Set Sue
Hoses
Post by Socket Set Sue » Sun Nov 18, 2007 9:02 pm
Nice one Flippa, these two are a problemas far as pin holes are concerned.:-
You say "plus two i cannot identify using the schematic : so9g-61-213a heater hose, so9a-61212 water hose"
see http://www.lushprojects.com\bongoparts\pages\6125A Rear heating components.html
You will probably have to paste this into the address bar of your browser.
Post by Ian » Sun Nov 18, 2007 9:43 pm
To save you looking it up, the part numbers on page 6125a are:
61-212 & 61-213.
Socket Set Sue
Heater hoses
Post by Socket Set Sue » Sun Nov 18, 2007 11:08 pm
OK Ian, but if you do paste the web address into your browser you will be able to see, and identify, the two hoses in question.
John the sparky
Post by John the sparky » Sun Nov 25, 2007 8:58 am
I'm up for a set....
just can't decide on a colour :lol:
how long till they are available, do you think?
HOWIECLOLA
Post by HOWIECLOLA » Sun Nov 25, 2007 2:54 pm
Put me down for a set in blue.
Thanks.
